I have a boiler for heat/hot water, with multiple zones. It is a backup for a ductless mini-split installation. I'm trying to work something out where the boiler actually does backup the ductless mini-splits automatically, so I'm adding wifi-enabled thermostats where I can.
The boiler control board is a Honeywell Model L7224U. The manual for that is here: https://forwardthinking.resideo.com/related_links/thermalsolutions/l7224u/install/69_1720.pdf
I'm trying to do things properly, so if I can, I'd like to use the common in the boiler control board, but I'm not sure if there is one. I can't find any reference to it in the manual, certainly. I'm attaching a picture of the control board schematic and the current wiring.
The system wiring is a mess, some dating I think from the 60s, and needs to be cleaned up, so I don't have a complete diagram of that, yet. And some zones are already using a separate transformer for power, not hooking up to the boiler control board. But, again, if I can do things properly, and use a common from the boiler control, I'd like to do that.
