Looking for a good way to tightly connect two round rods in a T configuration.
I figured something like a T-clamp would be the obvious solution and easy to buy, but I have searched rather extensively and the closest thing I've found online is This, and from the measurements quoted it appears way too big.
In my application the vertical part is a 3/8" diameter steel rod, and the horizontal crossbar is a 7/8" diameter wood handle (to twist the rod). The rod is already inserted into a hole in the handle, but after many years the handle is now slipping, hence the need for a fix.
Can anyone suggest a reasonably simple means to secure the handle so it won't slip? I know I've seen T-clamps in pictures somewhere, but if they aren't as commonly available as I thought, I may need something different.
The local Home Depot has told me on the phone that they don't have anything like this.
Thanks.
11
    How muck torque is involved with the turning?
    – JACK
    Oct 11 '20 at 20:42
  • A photo of the thing you are trying to repair may shed light or stimulate an alternative fix.
    – Alaska Man
    Oct 11 '20 at 21:37
  • The specs on the product you linked to say 1 5/8" X 1 5/8" so that would be for a 1 5/8" pipe or handle, a little larger but not smaller. NO?
    – Alaska Man
    Oct 11 '20 at 21:43
    I wasn't sure. I thought the 1 5/8" was the length/width of the product. Actually it didn't "look" that big in the photo (to me), but later, I realized it could be the intended diameter. Anyway if that's the case, it definitely won't work for me.
    – Warren
    Oct 12 '20 at 0:12
    why don't you bend the rod into L shape?
    – jsotola
    Oct 12 '20 at 0:39
You might be able to find an appropriate clamp, but this appears to just be an irrigation shut-off key. They are not expensive brand new and I'd bet that the whole new key doesn't cost more than whatever speciality clamp you might ultimately find
  • This is not a standard handle. It was put together from scratch by the previous owner of the house.
    – Warren
    Oct 18 '20 at 5:03
  • Ok @Warren but the valve surely is like other valves, right? So handles built to activate valves might work
    – Matthew
    Oct 19 '20 at 1:21
