My AC condenser is done for and needs to be replaced. The evaporator coil is 15 years old and still working. I could get both replaced at once, or just replace the AC condenser. Doing both will cost around $2300 more than doing just the condenser. Is it worthwhile to do both, or better to just do the condenser.
Another option might be to install a heat pump to replace both, but I'm not sure if that's how these things work. I'm a layman and don't know much about these topics.
