-1
To the right and left of my front door are 6" deep protrusions/doorposts covered in stucco. I'm pretty sure (from another home installation project) that these posts are not really doorposts but are stucco over rigid foam insulation.
I want to mount a video doorbell (weight less than a pound) to this area next to my front door. I have bits that are diamond tip rated to go thru the stucco. I can even get a hammer drill if needed.
My concern is how to get the two anchors to hold if there is nothing behind the stucco other than rigid foam insulation.
The frame for the doorbell is what is actually mounted and holds the doorbell which needs to be periodically removed for charging. So, the mounting frame for the doorbell will be jiggled and wiggled somewhat as the doorbell is removed for charging and then re-attached. My concern is the anchors will loosen or never hold to begin with.
I have thought of drilling the holes (6mm drill bit recommended by product) and then filling the hole with caulking or hot-glue before inserting the anchors . Have no idea if this would work.
What's the best way to deal with this job?
  • To aid your searches, that stucco-over-foam is most commonly referred to as "EIFS" (Exterior Insulation and Finishing System).
    – Nate S.
    Mar 8, 2021 at 22:09
It would be important to find out if the entire column is rigid foam, or if it has a wood/steel/concrete/plastic core. If it has a core, you can use whatever type of fastener is ideal for that material (and long enough to penetrate the foam layer).
If it is truly rigid foam all the way through, you might consider drilling a hole and then using a molly fastener which when engaged would push hard outward from the hole against the rigid foam. Some kind of slow-drying glue or epoxy may help enhance that effect.
Otherwise, you're probably looking at some other kind of preparation. If you can engage a block of wood large enough (2x4 or 1x4) to mount the doorbell bracket, you may be able to embed it with glue and repair the stucco around it so it looks somewhat natural.
    I'm thinking that the only way to determine what the core is - is to drill a pilot hole of some sort. Maybe in an area that will eventually be behind the bracket. would that be your approach for determining the core?
    – user163862
    Oct 9, 2020 at 22:49
  • @user163862 Yes, that ought to work. Oct 12, 2020 at 13:11
    I would think a molly bolt would very likely cause cracks in the surface spreading out from that point. What I'd do instead is drill a bit bigger hole, glue a wooden dowel into it, and screw into that (or preferably all the way through that, into the sheathing behind.)
    – Nate S.
    Mar 8, 2021 at 22:12
