At my house, the previous owner was a huge fan of propane. I've got gas lines running to the main floor fireplace, a basement fireplace, kitchen and the deck. All I ever use and have hooked up is the main floor fireplace, and even that only during winter time.
The previous guy had a massive 500 gallon tank in the back, since I have no use for that much and I wanted to avoid renting it, I opted out for a smaller, 100 pounder.
The problem is, the 100 pound tank doesn't work, it feels like there are so many pipes around the house, even with the taps closed at the edges, there isn't enough pressure and I need a larger tank just for the sake of getting the pressure to power a single small fireplace.
Another supplier said that because of the freezing winter temperatures, 100lb tanks aren't usable and I need at least 420lb because in the smaller tank, in cold weather, the propane wouldn't vapourize, so while 100lb is enough to provide the pressure, it wouldn't work anyhow.
Since I've run into some not-quite-honest providers around here before, I'd love some real input on what to do here.
My plan right now is to simply disconnect all the gas pipes at the source and install a new pipe only for the fireplace I want to use, and stay with the 100lb tank.
Any ideas and solutions are of course welcome
