As a home owner, I have an ongoing issue which is that everytime any motor kicks on (refrigerator, AC condenser, sabre saw, etc.) the lights dim for a second or two. The main service is at the detached garage and is properly bonded and attached to a grounding rod. This panel feeds the sub panel which is located in the house about 50' away. This sub panel is also bonded and attached to both a grounding rod and cold water pipe. I questioned the electrician about this and he said that it was required by code since they are 2 different buildings. BTW, the work was inspected. Is this accurate? Is this why I'm experiencing the temporary voltage dips, or is there another possibility? Much thanks.
    How many amps is your incoming service? This could be a few different things, some of them relatively benign, others rather problematic. Also, how many wires are in the feeder to the house from the garage? – ThreePhaseEel Oct 7 '20 at 1:51
    Does the subpanel have a neutral-ground bond also, or is N and G separate? You know North American/JP power comes in 2 separate "poles" of 120V totalling 240V... what is the voltage on the 2 different poles? Are they solidly within 1-2 volts of each other, or do they spread out sometimes when a big load is on one pole? – Harper - Reinstate Monica Oct 7 '20 at 4:02
  • How far is the main panel from the transformer? And did you put a meter on it to see how much of a voltage dip you have? And what type of lights? Many LEDs are notoriously sensitive to voltage variations. – George Anderson Oct 7 '20 at 15:54
  • 50’ is not that far but the size of the sub panel and the brand of the main panel would be where I would look. A single family home should be on a 100 amp feeder and that it is fed from a main panel that usually means a snap in circuit breaker. I have found many times when large loads have dimming on multiple circuits it to be connections at the main panel causing a dip during the peak load (when the motor spins up) 2 specific brands of breakers/ panels that are notorious for problems are FPE stablock (federal pacific) and Zinsco if your main panel is ether one of these read up on them. – Ed Beal Oct 7 '20 at 21:51
