Hello Stack Exchange,
I'm a new homeowner that bought a house originally built in 1920 and has been since remodeled. It is my understanding that the previous owner attempted to remodel and add wiring to the house, but all knob and tube wiring. Then, the next owner (a contractor) remodeled the home and simply removed the knob and tube and wired the house very confusingly. For example, we have several ceiling lights that now cannot be turned on due to issues in wiring.
I'm wondering a few different things:
  1. Based on the pictures, I really don't know how safe this is, but I'd love to hear some feedback from the community.
  2. How do I go about mapping the electrical panel to each part of the house?
  3. Is there a way I can remove (or relocate) some of the circuits that are now shut off? The previous owner had a hot tub (again, wired through knob and tube) and the contractor just shut the circuit off. So I'd like see if I can reuse it.
  4. Finally, there are some live wires with cloth wire coating. Should these be replaced?
I'm definitely comfortable working with electrical wiring, so I'd like to give whatever I can a shot before calling in an electrician. Whatever feedback the community can give would be greatly appreciated!
Thanks in advance, Dan
Wires coming from electrical panel
Additional unused wires
[Electrical panel
Wiring through joists
  • Other than some rats nest in the 3rd photo that we can’t quite make out I see NO knob and tube. I see som bx or flex and a rats nest but no K&T mostly Romex so get a better photo ov the mess in photo 3 but you have a breaker panel and other than the rats nest everything looks fine even better than homes built 40 years later!!!
    Commented Oct 2, 2020 at 0:42
  • Out of curiosity, do you mind posting a close-up shot of the label on the inside of your breaker box's door please? Commented Oct 2, 2020 at 2:10
Identifying circuits
Step 1: Most of your breakers are labeled. Start by checking the labels by turning them off one at a time and verifying that the indicated device was shut off. Then make a list of all the lights and outlets, and all the breakers that are not yet matched.
Step 2: This requires two people with walkie talkies or cell phones. Organize the unidentified lights and outlets into groups that can best be observed from a central location. EG, several bedrooms can be observed from the upstairs hall. Plug lamps, TVs, radios, whatever into the unidentified outlets. One person stands in the basement and turns off each unidentified breaker in turn, one at a time, and the other stands in the central location and lets their partner know what lights and devices are shut off. The person at the breaker box takes notes. If you’re using cell phones to communicate turn off wifi on both phones because you’ll be turning your wifi network on and off frequently. Repeat this exercise once for each floor at least. Don't attempt to ID every single outlet at this stage. Just most of the ones that can be easily observed using this technique.
Document all your findings on paper or a spreadsheet. Don’t attempt to do it on the panel, there isn’t room there.
At this point you should have most of your outlets and all of your lights matched to breakers. Some outlets will be unidentified because you just missed them, and some breakers will be unidentified for various reasons.
All the above will take about an hour.
Step 3a remaining outlets: Do this gradually over weeks or months. Whenever you have an outlet that hasn’t been identified use a Breaker Finder (about $40) to figure it out (no partner required). Buy one of these. and keep it handy. You'll gradually identify all remaining outlets.
Step 3b remaining breakers: Turn off all the unidentified breakers. Make sure all your critical devices (fridges, boiler, sump pumps, etc) are working. Then leave them off, and you’ll gradually figure out what’s not working when you discover dead outlets or devices. You’ll likely find some of these quickly as odd random outlets in the kitchen, bathrooms, and hidden behind furniture.
Dealing with disused breakers and wiring
You may have unused wiring in your home where there used to be, e.g., the jaccuzzi, or window A/Cs if you now have central air, or electric appliances if you now have gas, and so on. If your basement is unfinished you ought to be able to trace most of these visually. You can remove the front panel from the breakers and literally trace the “off” circuits to wherever they go. You want to make sure these wires are all correctly terminated in junction boxes. If so you can leave them, or disconnect them at the panel and remove them from the panel, or remove them completely.
If disused wires are modern, safe, and safely installed you should consider, rather than removing them, re-using them instead to ensure that critical devices like fridges and all your wifi electronics have their own dedicated circuits.
You may find disused wires improperly terminated, e.g. just loose in the ceiling. This could have been done by a non-electrician contractor removing an old A/C or other device. Deal with those as above: Either put the end in a box, or disconnect and/or remove the wire entirely.
If you are going to physically remove a lot of wires from your breaker box, hire an electrician to do it. There are dangerous permanently-on areas at the top of the box, and the more work you do near them, the more likely you are to make a careless mistake.
Dealing with older wires
Your wiring seems mostly upgraded and installed properly. There is no knob and tube in any of your pictures. There’s nothing that cries out to be replaced just for the sake of replacing it. Are you sure you know what knob and tube is? Look it up. Post pictures clearly depicting what you think needs replacing because of its age or construction. It's very unlikely that knob and tube was used for a hot tub, and if it was, I'd love to see the hot tub for historical interest.
Start at the disconnected end of the unused wire and follow it back to the other end removing it as you go.
You should do this while the power is turned off.
if it comes to a branching junction remove it and re-make the join (or leave a stub with a cap on it)
check the other branches to see if they are used.
