I am DIY-ing a house in Montana where a mobile home used to exist nearby (150ft away). There is an existing NG meter (250CFH). Of course my home is much larger and needs a little over 500 CFH. This does not include the demand for a future planned shop. The main line will support me, but the meter must be swapped regardless (at the utility company's cost). The current meter is at/near the future shop location. This is important to remember (if I move meter to house, I still need gas for shop eventually).
The question is - pay to move the meter ($2200) or install my own gas line? Paying to move the meter is a simple solution that is done by someone else per the utility company requirement.
My own gas line: This is a 150ft run. I would need a 2" inch line at 2PSI (gives me 900 something CFH) and the utility company is "uncomfortable with this, but will do it." However, isn't the 2 PSI an issue for appliances? Utility company won't advise on things beyond meter. But, seems like I'd need some pressure reduction system for each device? One for entire home?
My appliances are: Gas HVAC: 200k BTU Gas on-demand hot water: 250k BTU Gas dryer: 25k BTU Gas cook-top: 45k BTU
Future: Pool heater possibility and exterior BBQ.
