I'm attaching about 2 dozen electrical "handy" outlet boxes to a new workshop. They will attach to the metal wall purlins, with the wires fed from the top through EMT conduit. Instead of using self tappers to attach them I want to use stainless rivets.
I'm assuming this if fine (I can't find anything in code); but don't want to attract extra scrutiny from my inspector.
Here is the final result: enter image description here And on the "hoop" section walls of the Quonset: enter image description here
More photos. Where the boxes went to the "gap" side of the purlins, we attached a piece of c-channel to give us a mounting flat as on the switch box and lower dual duplex receptacles boxes mounted to purlins with rivets
The code requires that the box be "rigidly and securely fastened" to the purlin. Rivets seem OK to me, and I think would seem OK to most inspectors. Having some specs on the mechanical strength of the rivets might help you if there's a question.
Rivets are specifically mentioned as an acceptable way to fasten a box to the frame of a ceiling grid. To me that helps you argue that they are OK to attach to your purlin. On the other hand, the inspector could argue that the ceiling gives the box some protection and something more rigid and secure is needed exposed on a purlin.
