Moved into this house last year , Trying to figure out what this button does ? the white wire goes to garage opener. . Tried pressing it while the garage door is opening/closing ,nothing happens.
What happens if you press it when the door's not moving?? – JACK Sep 29 '20 at 0:18
Did you try it while the door was closed or open. My button cycles the door. opens it if it is closed, closes it if it is open. It does nothing if the door is in motion. – mikes Sep 29 '20 at 0:20
1Can you add a photograph of how the wires attach to the opener? – DoxyLover Sep 29 '20 at 0:29
It Does nothing when the buttton is pressed when door is not moving. just found out it is not connected to anything . i will climb and see to which port this wire should connect to ?. – Shivakiran Neelagiri Sep 29 '20 at 0:58
@mikes, Is it used to force close/open garage door incase safety sensor is not working .? – Shivakiran Neelagiri Sep 29 '20 at 1:02
