I recently purchased a kit to enable me to put in some raised flooring into my loft (as my house has double-thickness insulation). This kit contains some supports which screw onto the wooden joists and some metal rails that you put on top of the supports, and you then put your boards on top of these rails.
Here's a picture I took:
As you can see the wooden joists go horizontally, and the rails and supports are at right-angles. Each joist is spaced 610mm and each of the rails is spaced 610mm (it's a 2.44m x 2.44m square).
I am going to be using 610mm x 1220mm OSB for the boards.
Now my question: what is the best way to orient these boards in order to spread the load across the joists best?
Would it be better to put them horizontally so they span three rails (Option A) or vertically so they are supported either side on two rails (option B)?
Here are some diagrams I threw together to illustrate:
The reason I ask this question is that my physics is not my strong point, so I was thinking that option B would perhaps be better since the load would be spread over three wooden joists rather than two, however, this would then place the load on two rails rather than three.
    I would think it's more about the support for the plywood/OSB you're laying down than spreading the load across the joists below, since, so long as you store stuff reasonably evenly, the load will be spread reasonably evenly.
    Sep 28, 2020 at 14:07
The load will be transferred to the supports mostly based on how you stack it, not how the sheets are laid.
OSB has a dedicated (and labeled) strength axis. It's normally lengthwise with the sheet. While your OSB may be thick enough that it doesn't much matter, it's almost never appropriate to run it parallel to the joists. If you don't have a compelling reason to do otherwise, install it perpendicular with the joists.
Also, stagger the sheets. You should not stack joints like you have. Instead, start the second row with a half-length sheet and lap past the first butt joint with a full sheet. This allows the tongue-and-groove connection between sheets to help support the area around the joint. Even if you're not using t&g doing so will help stiffen the floor.
    "it's almost never appropriate to run it parallel to the joists." Just to confirm, you mean parallel to the new, metal floor joists, not the existing wooden ceiling joists, right?
    Sep 28, 2020 at 14:08
    Right. The joists to which they attach.
    Sep 28, 2020 at 14:09
    And stagger this is probably the most important thing to do for strength and load distribution.
    Sep 28, 2020 at 15:39
