I am a renter with water pipes that are inaccessible at some points, and which may freeze in the winter. I am doing my best to prevent this, including heating my apartment, trickling my faucets, and potentially doing some more insulation or electric heating.
If my pipes freeze and I try to thaw them out by using hairdryer or other similar heat source to apply heat to a single point along the pipe, can you give me any rules of thumb for how long of an ice block I could reasonably expect to melt? This probably varies based on various factors (like maybe the pipe material/dimensions, the temperature, the heat source, etc), and I would be interested in a range of conditions.
For specificity, you can imagine that the pipes are copper, the temperature drops to 10 deg F (-12 deg C) area and remains there for 12 hours after the freeze, and I use an 1800-watt hairdryer.
