I have a new champion generator, 120volt at 20 to 30amp. The previous home owner had the same unit but 240 volt. The home has a professionally installed system for power backup but has a 4 pin 240 volt outlet as per photo.
My question is, can I adapt my unit to the 240 volt system which I think is split phase because it also runs a 1.5HP well pump motor?
