I was wondering if I could run 120v wires inside in a larger conduit that has higher voltage wires 240v, in a smaller piece of conduit?
The reason I ask is that I have a manufactured home and when they installed the 240v wiring coming from the meter it is run under the house in the crawlspace. It's not in conduit untill it enters the bottom of the electrical panel. When the water pump (120v) was installed they just ran it into the conduit with the 240v wiring.
I know for certain you can't run low and high voltage in the same conduit, but I thought that if I ran a 1/2" conduit inside the 2" for the 120v that would rectify the violation.
