My basement sink is a two-tub sink with each basin's drains as close to each other as they can be. Below is a picture of the actual drain piece beneath the sink - it is an integrated two-in-one drain, as you can see. Obviously it needs replacing, but I can't figure out what to Google to get this same piece. Any insight?
I have a more modern kit that just connects two separate drains, but the drain pipe exit to the wall is fairly high relative to the sink drains and I'm pretty sure adding any extra stuff is going to put me too low.
