I am planning to redo a small walk in shower. 60" x 32".
My plan is to rip out walls, replace with concrete backer, and redguard the entire thing. For the floor, it currently has small glass mosaic tiles. I want to remove this as well, sand down the old thinset and redguard the floor.
Does that make sense so far?
For the remodel: I plan to order and install shower panels for the 3 sides. My question is, I want the pebble mosaic style floor and would apply this to the ground. Can I use the panels with a tile ground? How would you best seal the panel to the floor without the panel base kit.
I hope this makes sense, please let me know!
