I have a 3" cast iron toilet drain pipe that runs vertically inside the wall from a second floor bath down to the main drain under the house. I am putting a two gang meter base (it's a duplex) on the outside of that wall. What is the required horizontal distance between the meter base and the pipe?
Thank you!
