The goal is identify hot and neutral wires in a 3-way switched line-array of lights, so that the array can be controlled by an Acuity SP20 Secondary Relay Pack (bottom device):
Said line-array of lights is the only 3-way switched several line-arrays. The other line arrays are controlled by a single switch. Said switches form a bank of switches at the building entrance.
The target line-array is located between the two switches:
Is there any reason to doubt that the wiring diagram above represents how the switches are wired? or maybe the better question is: How can I confirm that the that the diagram represents said line-array and that the hot and neutral are located at the switch bank located at the building entrance? Diagnostic procedures that are simple / less invasive are preferable
The sub-goal is: How to identify which common terminal of the 3-way switch is connected the hot wire (left 3-way switch) vs, the switched hot wire (right 3-way switch)
  • Clear pictures of the actual boxes would help this question.
    Commented Sep 23, 2020 at 12:09
  • Is there any reason to doubt that the wiring diagram above represents how the switches are wired? ... yes, the diagram shows how the switches could be wired
    – jsotola
    Commented Sep 24, 2020 at 3:06
Turn off breaker. Disconnect wires. Connect appropriate meter (safely). Turn on breaker, look at meter. If no voltage, turn off breaker, move to other switch, connect meter, repeat.
Or use a test lamp, if you are old-fangled. The folks around here are fond of "non-contact voltage testers" but they appear to be prone to confusing results. I'm old-fangled enough to prefer a meter, but not old-fangled enough to prefer a test lamp.
If your switches were actually wired "that way" you'd have a neutral connection in one box, and none in the other box. But things are often less clear-cut than that in practice - can't hurt to look for it, though.
    "old-fangled". I like that mashup of "old-fashioned" and "new-fangled". I think I'll borrow that one!
    Commented Sep 23, 2020 at 12:11
    This old-fangled guy wouldn't be caught dead with a wonder stick (non contact VT). Give me a meter every time.+1
    – JACK
    Commented Sep 23, 2020 at 12:24
  • Yikes! My preference for a meter puts me in the old-fangled category :)
    – gatorback
    Commented Sep 23, 2020 at 12:30
I can't make sense of any of that German spaghetti. Here's how 3-way circuits are actually wired:
or
As well as 3-4 other possible rearrangings-of-furniture, giving the same wires doing the same loop, but on different routings.
Yeah, lots of reasons to doubt. 3-ways are always the same loop electrically... but topologically, there are at least 5 different arrangements by which the wires could be routed.
That is why I favor a functional approach of positively identifying the always-hot, switched-hot, and traveler wires, and marking them as such e.g. with colored tape.
  1. 3-way circuit must be working. 2) Measure it. 3) throw a switch. 4) Does it change?
As usual with smart devices, here is the takeaway:
Smart switches usually need always-hot (black in my diagrams), neutral (white) and often switched-hot (red). As you can see, this may not exist at some or any switch location.
As such, your choice of potential place to put a smart device may be limited, or nonexistent, without a complete reinvention of the circuit using smart tech.
  • Interesting diagrams! The wiring inside the light fixture is red and white: reasonable to hypothesize and verify that the red wiring in fixture is switched hot and white is neutral? How to physically verify?
    – gatorback
    Commented Sep 25, 2020 at 1:02
