Converting a tub to a shower, and with the drain location changing I'm just getting back to the underbelly and seeing the alignment of things before hooking it all back up.
You can see the new drain now sits into the room roughly 1.5-2in as compared to the max reach of the new p-trap. I put a piece of 2in into the drain to illustrate the shift. Side note, I do realize I will be transitioning from 2 to 1.5in, which is OK per code and flow rate of the shower head in my area.
I was hoping the extra pipe going to the p-trap was going to be the place to splice in, but now I'm not sure. Should I be rebuilding everything between the lines? Playing around with elbows to get it over to the new drain?
I'm comfortable working with ABS - just want to be sure it's the best approach.
  • Do my eyes deceive me or are you feeding the new trap into a sani-T with the 'leg' pointing down into the old trap?
    – brhans
    Sep 23, 2020 at 13:23
You should cut the 2" main line (at the location shown in the first picture) and rebuild the assembly entirely, eliminating the combi (reducing tee) and any 1 1/2" components and orienting a new 2" sanitary tee to the correct angle to line up with a new 2" trap located directly under the shower drain. Why on earth would you reduce to 1 1/2" here when you could very easily make this all 2"?
    Yes! Not the place to "save" $10 on fittings.
    Sep 23, 2020 at 11:51
    If I wasn't needing the eliminate and rebuild, I didn't see any harm in it? Given the need to rebuild, though, I will go with the 2" to the assembly. Makes sense, and saving a few bucks here isn't a driving force @Ecnerwal. Thanks for clarifying!
    – CFA
    Sep 23, 2020 at 13:17
  • A 1.5" pipe is barely over half the size (area, capacity) of a 2" pipe. 56.25% if you want to get picky. Thus, a 2" trap is one heck of a lot harder to clog than a 1.5" trap, even if your local code permits. Since most (all?) shower drains are 2" drains, under ICC (which I have to work with, subject to my local modifications) I think it would be caught by the "you can't reduce the size of a drain" rule, but I may be interpreting too strictly, or I may not have looked for 1.5" shower drains.
    Sep 23, 2020 at 13:24
  • For sure. I look forward to the flow with the 2" setup, then! Thanks for your thoughts.
    – CFA
    Sep 23, 2020 at 14:55
