I'm trying to remove a kitchen faucet, and I can't figure out how to remove the faucet with these weird 'elephant ear' brackets. Can anyone identify them or provide a suggestion on how to remove? Thank you!
https://i.sstatic.net/b7KYJ.jpg enter image description here
  • Care to tell us what brand (and even better) what model of faucet this is?
    Commented Sep 23, 2020 at 15:03
  • Can you provide a photo from the top? Wondering if this faucet was glued in place. Commented Sep 23, 2020 at 16:26
Looks like it was a Costco faucet, and once I realized that the hex screw was covered up by mineral deposits, I cleaned it off and I was able to use the link below to get it off easily.
Both images from TerryLove.com
  • I'm glad you got it sorted out. Please give yourself a check mark for your answer as soon as the system will let you. Also note that I embedded the key images from the link you provided. Embedding images/key descriptive text (with appropriate source attribution) is expected here because links can die in an internet-instant, which would render your answer useless in the future.
    Commented Sep 24, 2020 at 15:14
these 'elephant ear' brackets are fixation kits, the function is just like a washer. firstly you need to remove the silicon glue, and then use a suitable spanner to unscrew it , then you can remove the brackets.
  • Generally, I'd agree with you, but I don't see anything to attach a suitable spanner to. Care to download a copy of the OP's picture and draw an arrow or two on it showing where the OP should use the spanner, then edit it into your answer?
    Commented Sep 23, 2020 at 15:00
Looks like you need to sort out access from above (partial faucet disassembly, presumably) to turn the screws.
