I currently have 14/3 from my panel to a switch box. The switch box has 2 switches, set up such that one switch would turn on the lights of fan/light combos, and the other switch turns on the fans. From the switch box, I have run 14/3 to the location where I was going to hook up the light/fan combos. Since running the wires, I have changed my mind, and would instead like to wire up a fan (no lights) and lights. I have the 14/3 wire still sitting out, ready for use, but my question is: can I use the existing set up (the two separate switches and the 14/3) to wire a fan and string of lights separately such that one switch would turn on the lights and the other would turn on the fan?
I hope I explained that correctly.
  • Hello, and welcome to Home Improvement. If an answer is helpful, please click the large check mark next to it to accept. And, please take our tour so you'll know the details of contributing here. Commented Sep 21, 2020 at 2:52
  • This is done all the time. No problem.
    – Hot Licks
    Commented Sep 21, 2020 at 12:17
Yes, that will work. Terminate the 14/3 (neutral and two switched hots) in the ceiling fan box where you'll hook up the neutral and a switched hot to the fan. Then connect the 14/2 for your light to the neutral in the fan box and to the other switch hot. Run the 14/2 to your light locations. You will naturally want to hook up all the ground wires to these fixtures.
