I picked up a used 10kva (45a) Generac unit and want to get it connected thru the transfer switch. Just looking for some feedback on how to get it connected. I was going to use 1" schedule 40 indoors for runs of the 6-3 NM-B (about 75' total) and four 14 ga THHN control wires in a separate 1/2" schedule 40, switching to schedule 80 before it goes outdoors. Then have a type LB on the exterior, then run the control wires directly to the generator and have the 6-3 going to a disconnect box. After the disconnect I was going to use either more schedule 80 or non-metallic flexible conduit with watertight connectors to the generator. As you can see, everything is above ground.
So my questions are:
