I'm replacing broken glass in my display cabinet door, with glass on order.
When removing the old glass and glazing I tried to salvage as much as I could, including the thin wooden strips that divided the glass pieces. However, it is clear that they are unsalvageable and need replacing also. The only issue is... I have no idea what they are called or where to buy them.
Can anybody help?
I am assuming they are a specialist piece, rather than just a wooden strip?
I have measured the dimensions to be: 18mm (height) x 1mm (width) x however long they need to be.
I did find something like this online for model boat making; I'm nust not sure if it's suitable and could do with some guidance.
FYI: I should also state that the strips should be flexible enough to fit the shape seen in the pictures below:
