I would like to trade out my current stairway lighting which is Crestron master dimmer/2 slave dimmers and replace them with 3 standard 3 way switches. Once the Crestron units are removed, is the wiring for all the 3 new 3 way switches as usual with hot to common and travelers on the remaining screws?
  • Can you post photos of the insides of the boxes please? – ThreePhaseEel Sep 19 at 1:08
  • If the three switches are for the same lights, then you'll need 2 3- way switches and a 4-way switch. the 3-way switches would be wired hot to common and two travelers and light to common and two travelers. The 4-way switches the travelers from both 3-way switches. – JACK Sep 19 at 1:13
  • Thanks, problem solved. – Howard Sep 25 at 3:25
