My Kenmore 596.51679100 side by side fridge is tripping the dedicated GFCI circuit in my garage that it's plugged into and I suspect it's the defrost heater but I need to test this. As far as I can tell this model has no timer, but a thermostat and a control board. How can I force a defrost cycle to run?
Edit: This is in a garage, so all outlets are, by code, GFCI protected.
    Nuisance trips like this are the reason it's recommended that refrigerators not be plugged into GFCI protected outlets. It would suck to leave for a long weekend only to return to a fridge full of spoiled food because it decided to defrost, tripped the breaker, and slowly got warm while you were gone. – FreeMan Sep 18 at 18:06
    Everything I read says it's code now for appliances in garages to be GFCI protected (in fact all garage outlets should be), and that outlet is specifically designated for a freezer/fridge, so it's on an independent circuit. And this is a beer fridge, so I'm not worried about spoilage. – The Shoe Shiner Sep 19 at 10:56
  • Ah. I see you've edited that into your post now. Good to try to remember to include things like that up front to avoid confusion from potential answerers. Unfortunately, I don't have an answer for you. – FreeMan Sep 19 at 20:53
  • After doing some reading, it seems that best approach is to replace the GFCI outlet with a normal 20a outlet. This doesn't meet the code perfectly. However, the outlet is on a dedicated 20a circuit, in the back of garage, 4ft off the ground, and not readily accessible, so given those circumstances it seems that it's fairly normal, and safe to use a normal outlet. – The Shoe Shiner Sep 20 at 0:22
