I removed some trees and now widening my driveway as illustrated in the image below. Not sure how to proceed because I'm stuck on the following questions:
- What type of driveway is it? Dirt? Crushed blacktop? One thing I'm pretty sure of is that there must be a layer of crushed stone or gravel underneath because my driveway has been quite stable.
- If I widen the driveway, do I have to change the crowning from the solid blue line to the dashed blue line or can the high point remain where it is?
- Can what I'm trying to do be accomplished by adding material (i.e. 3/4" crushed stone + something finer - if so, what?) on the right. What I'm trying to avoid is a major digging project which achieving a consistent look across the width of the driveway.
