I'm replacing an old led light fixture that is on a dimmer knob. The new light fixture is also LED but motion activated. The instruction manual says do not install on dimmer circuit. Basically I want to know why not, and is it ok to disregard this warning if I don't care about the dimmer effect working?
This will be a temporary fixture until we get a contractor out to have some proper work done. I need to have motion lights as a security deterrent ASAP.
Basically can I install the fixture anyway? If not what do I need to do, would it be a simple wall switch replacement? Or the entire wiring needs to be redone?
