I am renovating my kitchen and will be switching from gas stove to induction cooktop. The gas stove is currently hooked up to a 3/4 inch iron pipe coming through the subfloor (below it is a drywalled finished basement). The wall where the old stove is located is coming down, so I cannot have the pipe sticking out.
Can I simply remove the valve, cap it off with a 3/4” iron cap and Rectorseal, and then 1/4 turn the whole assembly at the lower elbow so it is tucked away into the joist space? Or should I remove the pipe down to elbow and cap it with an threaded plug? The subfloor will be patched and then covered with a new hardwood flooring. Thanks.
