I just installed a new shower/tub combo where I had only a tub before. I ran pex up to the shower. I installed a female drop ear elbow then the shower arm. No leaks when open butt. When I put on the shower head, it leaks where the arm connects to the female elbow. I’ve tried teflon, thread compound. I’ve tried different shower arms. Nothing works. Any help would be appreciated. Thanks.
Many shower heads have a rubber washer in the female end. Does yours have one?– JACKSep 14, 2020 at 1:40
Yes. However, its not leaking where the shower head connects tot he arm. It’s leaking where the arm attaches to the elbow in the wall.– MattSep 14, 2020 at 3:38
Is the drop ear elbow very firmly secured to solid structure so that you can sufficiently tighten the arm/pipe to it ?– Alaska ManSep 15, 2020 at 19:00
1 Answer
Considering that you've had the same problem with multiple shower arms, and assuming you're applying the tape and compound correctly, the problem must be with the drop ear elbow. It's possible that the fitting is defective, or that there is a hairline crack you're not noticing. When you thread in the shower arm, it would cause the crack to expand slightly.
In either case, you will have to replace the drop ear elbow. I recommend using a brass fitting, rather than plastic, as plastic is more prone to cracking and thread wear.
