When I remodeled my house I had left over granite from the kitchen. I had the mason cut a piece for a built-in desk in a dormer. He first cut and polished a piece that wasn't the right size. I kept it with the intention of building a desk / table out of it in the future. I have now done that and the table looks just like I wanted it to - very minimalist - but there is a slight racking (swaying) side-to-side that I'd love to correct. I don't see any movement at all between the tops of the legs and the wood when it's racking, but I have to assume it's coming from this table-leg connection and not from an unlevel floor. The legs have adjustable feet that haven't helped.
I bought pre-build metal, rectangular tube steel legs. They're rated to hold 220lbs each. I connected them with flat-faced hurricane bolts to 3/4" plywood at 62" x 28" to fit under the granite. I then added a piece of 1x6 nominal hardwood across the belly to connect the legs and support the table. Outside of the wood I mentioned, the legs are independent.
With this setup (before the granite), I could sit on it without issue. There was still some racking, but I'm 240lbs. So, adding the 120lb granite weight didn't seem to be an issue. I now have had the granite just sitting on the plywood without any adhesive. It's been sturdy for 2 weeks.
Could someone please give me some ideas on how to possibly remove the racking without fundamentally changing the look of the table? If it can't be done, I'll live with it like it is.
I have come up with adding flat, angle braces in the corners to possible sturdy up the leg-table connection. I also thought of cutting 62" x 2" x 1/4" steel to bolt directly to the 2 legs to stabilize them from moving independently of each other. Like I said, I could probably add a skirt or some other boards or metal around the outside of the legs to make it not rack, but that would defeat the purpose of what I'm trying to do since I wanted a desk that I could work from one side and someone else could work from the other side.
Any help would be greatly appreciated. Thanks!
  • Your design is at risk from several issues. First the table sways because the leg frames on each side are not directly connected. The only thing linking the legs is the nut and bolt connecting each frame to the plywood. This is inadequate. The leg frames must be connected with welded cross tubes to create a rigid frame. Next the piece of plywood and the 1x4 cross piece are not adequate to support the marble top if any significant weight is applied ( a person sitting on it?). It is at high risk of cracking. (cont)
    – Ashlar
    Sep 11, 2020 at 23:56
  • Third the leg frames on each side may need a cross brace as well to prevent the legs from being pulled out of plumb.
    – Ashlar
    Sep 11, 2020 at 23:57
  • You are right, this is not a woodworking question. Wood solutions would require different solutions than tubular steel. I am closing this question as off topic. You may get some answers from the DIY site so I am transferring it.. Good luck
    – Ashlar
    Sep 11, 2020 at 23:58
The "very minimalist look" is a bit too minimalist for boring old function. You may regret "living with it" when it fails and a hunk of rock lands on your foot (or other body part), or someone else's.
Failure is very much an option. Fasteners can be ripped out pretty easily, and wood can fail when you have a long lever (legs) attached to them.
Adding a stretcher (compression brace) at or near floor level on the back side and X-Brace cables would still be quite minimalist, but far more functional. There are other ways to achieve the same end with various "looks." Since you want "double-sided access" some sort of angle braces on the corners are one option, and longer center braces from the top to the "foot cross bar" are another option.
Making something that "looked like this" but which was "actually stable" would be quite a design project and probably involve welded steel and sneaky tricks like getting some depth of bracing hidden within the depth of the table-top. You can rip welded steel apart with a lever-arm, too, if it's not well designed.
Unless the top is very low, an apron (not a terribly wide one) is in fact a very normal approach to this issue for tables, and it will be designed to let your legs slide right under it. Here you could use a curved apron with more depth (and thus better bracing) at the ends if the intent is to sit "in the middle" of each side, rather than "all around" as with the typical dining room table that typically has an apron for exactly this purpose.
2 pieces of 1/8" Steel bar 2" across were cut to fit in between the legs on opposite sides. These were bolted in with the existing bolts. This effectively created a steel table with wood and stone on top.
This completely removed the racking. I further tested the design with a dead load of 360lbs in the center of the table without the stone. This has sat for 48 hours now without any racking or sagging. That was enough to call my test a success. The stone adds 110lbs, but gluing it in will also add a little structure to the wood. This will be fine for laptops and coffee.
    According to Ecnerwal's excellent answer, the question is not a dead load straight down, but a live load at an angle. A visitor who tries to sit on or lean against the end of that table will apply more force than your proof load.
    – Valkor
    Sep 14, 2020 at 21:41
  • I just sat on the edge and then leaned on the desk from the end and there is absolutely no movement. The steel slats I added are wedged between the legs. They can't fold in until the steel would bend or the 10 bolts on 1 side would snap and they would have to break the stone that's glued to the board or delaminate the plywood, bend / break both steel slats, and break the 1x6 hardwood board to fold out. I feel pretty confident in it.
    – pennstump
    Sep 16, 2020 at 1:19
