I have a painted drywall ceiling and want to stick some low-density stuff onto it (things like rope, plastic, maybe some strips of wood). The stuff I stick on would not have a footprint that goes beyond the tape surface, but it might extend a few centimeters down into the room. I want some tape that would stay stuck for a long time with minimal shifting. I'm thinking of an indoor heated room in the US Midwest. Not sure what kind of paint/drywall.
Need more specifics: Does the tape need to be removal without damage to the paint? How long do you want the tape/taped item to stay up? How heavy is the item being taped up? – manassehkatz-Moving 2 Codidact Sep 10 '20 at 15:13
Thanks! I will add detail. – capet Sep 10 '20 at 15:15
Umm... this is odd. Usually the question is "what kind of tape comes off of drywall"! Darn near anything will stick to painted drywall far better than you'd want it to.
Masking tape will likely hold reasonably well, but may not support much weight and will dry out and fall off after a couple of years.
Duck tape (the generic cloth-backed stuff, not specifically the brand name) will hold a reasonable amount of weight and will last for years.
Duct tape (the aluminum/foil backed stuff specifically designed for duct work) probably won't hold as well as it does to to galvanized steel ducts
Gaffer's tape will hold about as well as duck tape and will, generally, come off cleanly, but will leave marks after a couple of years. (Ask me how I know)
Electrical tape probably won't hold all that well or support all that much weight.
Double-sided carpet tape will probably do the job quite nicely especially if the wall is pretty smooth.
Double-sided foam-backed tape may hold pretty well, especially if either the surface of the wall or item to be mounted is rough/textured.
Cool thanks! Haha, I did not realize how weird my question was, but now that you put it that way....I will mark this as the answer tomorrow. – capet Sep 10 '20 at 15:32
1no worries, @capet. Keep an eye open for other answers - there are lots of smart people 'round here with lots of different experiences. Someone may be able to give you something more concrete than "best guesses and logical thinking". – FreeMan Sep 10 '20 at 15:33
2“Duck” tape is actually just a brand of cloth-backed duct tape, no? It was originally intended to seal ducts, but it cracks and crumbles very quickly with the repeated heat cycling of ductwork and therefore is now recommended for anything but ducts—hence the switch to foil-backed duct tape for this purpose. – statueuphemism Sep 10 '20 at 15:35
1I vote for Double-sided foam-backed tape, given the shape of the objects you mention, as well as the likely texture of the ceiling. Moreover, the contact area is largest and mechanical tear-off stresses are least if the tape is fully in contact with the ceiling as opposed to having it wrapped half-around, and bracing the object – P2000 Sep 10 '20 at 15:35
1Tuck tape has the highest adhesion per square cm but too much and it will pull off the paint and the next layer if removed. Carpet tape will sag and fall off in hours or days. 1-sided red. canadiantire.ca/en/pdp/… – Tony Stewart Sunnyskyguy EE75 Sep 10 '20 at 15:35
