Good afternoon, First time here so I sincerely appreciate any help.. House background, built in 1907. Only electrical ever permitted was in late 70s. All else added etc done by previous owner was all done without permits. Mainly an illegal 45 foot trailer he had in backyard. I've cleaned some up but this is above me as I'm still learning electrical and while I'm getting there, and since affording an electrician is out, I bend to you...
Ok, by the pics, the double switch is what I want in the box with the gfi outlet. Gfi is as you see wired separate. The regular wall switch you see is outside the bathroom on my outside wall. Basically a 3 foot run. No idea what that outlet is fed off of but do know it in fact supplies the bathroom lighting. Originally, (I should have photographed) there was a single pole switch there beside the gfi outlet. If you can see the wiring ok, the hot from that outlet in the hallway was middle stripped and wrapped around the top common screw then either run directly to other common terminal and other wires nutted together or it was nutted with one light and other light was run into other common screw. Whew,
My goal is to have this double switch control 2 lights. One on wall (loose wires) and one to new fan light combo which I've already installed and wired to switch on together. When I hooked this all up first time, the top switch turns fan on, the other switch simply turned off that hall outlet. Power to the wires for light above mirror but not sure if its right till my light is delivered. But seems to have constant power regardless. What are my options here?
Thanks again [
[![hallway outlet
