How can I unscrew the central axis from my vacuum cleaner's motor. It appears it is sealed with some sort of green substance and it doesn't move at all. I already tried dissolving it with acetone and WD-40 and had no luck. Thank you.
1 Answer
Heat is a common method to make threadlockers let go - some specifically require it. Odds are excellent that it's Loctite Green or a knock-off of that. That specifically mentions "heat and hand tools" implying that it should not need high impact to remove once you heat it up.
2If locktight some heat and it may spin right off keep in mind it may be a left hand thread also.– Ed BealSep 7, 2020 at 14:51
