Due to an impact against it, the door lock casing in the wood frame has been uprooted. I managed to fix it back the metal part and some wooden pieces, but there still is a quite huge cavity with un-regular wood pieces inside.
Is there any way to fix it in a semi permanent way? I.E. Fill the empty space so i can paint it back to white.
Rearrange / any paste / paint?
