Installing a closet in the very corner of an old house. Note, I don't have a proper king stud, but two 2x4s with a plywood spacer in the middle. This is a load bearing wall.
I'm working with very limited space. Right now, it looks like I will end up with an 18 1/4" door which is inconvenient and looks ridiculously small. However, if I use 3/4" plywood instead of a regular 2x4, I would end up with a 19" door which to me is worth it. This is on the top floor, so there's no wall above it, but there is a ceiling joist roughly in the middle of the door. The floor in the attic is plywood screwed to the joists.
