I've got two pvc drain pipes in our basement that I'd like to route to the drain. Right now they're pouring out on the floor which is not great.
The large pipe says it's a 2 inch pvc pipe (though I measured the outer diameter of the pipe and it's more like 2.5 inch) and the other pipe isn't labeled, but it's outer diameter is 1.5 inch.
I know that I should get some kind of a coupler and connect the PVC to hoses to run to the drain, and I've found some couplers and hoses, but I'm not sure what kind of coupler and hose to use for this case because there are a bunch to choose from.
Any suggestions?
