The under the counter space for the washing machine in our laundry room is slightly too low for our washer. I can't push it in any further because the enclosure isn't perfectly square and the washing machine is too high.
I've already lowered the feet at the bottom to the lowest possible level. To make enough room, I'm thinking of shaving 1/2" or so from the plywood that between the countertop and the machine itself.
The floor is made of tile, and I could also pull out that tile to get the clearance I need, but I prefer to keep it in case of a leak.
Could I remove a layer from the wood under the granite countertop? Since it's already installed, I would have to do it upside down. I have a Dremel tool (with a router bit), a Dewalt Oscillating tool, an orbital sander, and I'm happy to rent something else if I need it.
Any suggestions?
Thanks!
ever-so-slightly too small
