I have an Amana where the HVAC coil drip pan must pool water to about a 1/4 inch before water starts to flow out the side of the pan.
I keep reading Standing water is not good to have because mold can grow. Or is this pooling water normal to have? Or should I do something to prevent that... ?
Unit is a split system in Phoenix, AZ.
- Air handler in Attic
- compressor is outside
