I've got a consumer-grade, 18 gauge pneumatic brad nailer that just blew a gasket. It's a discontinued model with no repair parts available.
The gasket I'm referring to, labelled as part 9 on the left side of the diagram below, goes between the head cap (part 8) and the housing for the piston (part 30).
For scale, it's about 2.25" x 2.5", a little over 1 mm thick, and about 1/8" wide (the thickness of the housing wall). It feels like it might be polypropylene. The gasket tore apart in use, allowing air to leak out too fast for the gun to be useful.
A replacement gasket needs to have a few characteristics:
  • The thickness needs to be very close to the original to provide proper clearances for the components inside.
  • The housing wall is only 1/8" thick, the shape is skinny and complex, and there's not much surface area. The gasket shape needs to be precise to accurately mate with the whole contact surface. The material must be soft enough to compress and seal surface irregularities, but rigid enough to not flex out of the gap under pressure.
  • It must handle 100 psi without ballooning out or tearing.
Is there a common sheet or caulk-like gasket material that would be suitable for making a replacement?
As supplementary insight, if any reader has attempted a similar repair, based on that experience, is a gasket of this type, tolerances, and complexity even practical to reproduce at home?
10
  • Have you tried that great big giant online auction site
    – Alaska Man
    Sep 1 '20 at 0:12
    Many auto stores have sheets of different gasket material and different types of Permatex sealants. You might want to check there.
    – JACK
    Sep 1 '20 at 0:28
  • @JACK, yeah, auto stores are a good source for a range of materials. The problem is knowing which material would be suitable for this situation. It's a little different from a typical gasket job, like on an engine. Unfortunately, the products don't list whether they will work for these requirements. It may be why the gun manufacturer used molded plastic rather than a more typical gasket material.
    – fixer1234
    Sep 1 '20 at 0:43
    I am suggesting to just search the model number on the site and see what pops up. You never know, there are parts for all kinds of things or units sold for parts. You could search for parts on the internet as a whole, there may be some old parts place that has New Old stock gasket.
    – Alaska Man
    Sep 1 '20 at 0:52
    i've used hot glue to fix something like this where parts were not available.
    – dandavis
    Sep 1 '20 at 16:47
I have found sheets of neoprene rubber, silicon rubber and the high temp stuff that looks like card board on line. On my nail gun senco they wanted ~22 for the replacement gasket plus shipping , I tried silicon sheet two soft blew out, neoprene rubber sheet it has held up I ordered a bunch of thickness but ended up using 1/16” exacto knives are really handy for cutting the neoprene. I should note I did try the high temp paper first as I had some for making gaskets for my compressor. Those blew out before it got to pressure. I think the neoprene 12” square was only 3 or 4$ I would give that a try.
Yes, a sharp knife, cutting board, steady hand, good marking out, patience and of course suitable material.
Made gaskets for many things using paper, card, plastic etc
One source of plastic useful in the past was a milk container, but temperature is a consideration.
  • So it's reasonable to cut a matching gasket of this style by hand with some material, and if it's a suitable material, it should work; sorta passes the sanity check that it could be made at home. Any thoughts on the meat of the question, what would be a suitable material? Lots of materials can be used in some circumstances. Paper or cardboard wouldn't hold up. I had thought about an HDPE jug but it isn't rigid, thick, or smooth enough.
    – fixer1234
    Sep 1 '20 at 7:22
  • I have a dozen different sheets of gasket materials some like cardboard or whatever and some out of neoprene different thicknesses a sharp knife and patience you should be able to make it, all purchased online not very expensive. +
    Sep 1 '20 at 7:35
  • @EdBeal, most common gasket materials won't work for this. It's a very thin rim of material with no lateral support, that fails if it moves, and it's under 100 psi.
    – fixer1234
    Sep 1 '20 at 8:13
    I have made the gasket for my senco framing nailer out of neoprene. It is almost the exact same part. It doesn’t get hot so the neoprene in my case works just fine. If it got hot I would the high temp cardboard like stuff. The neoprene although hard is pliable and when squeezed it has held up for years. I run my gun at up to 120 on old wood.
    Sep 1 '20 at 8:23
    @EdBeal, that sounds like an answer to the question. Why don't you post it.
    – fixer1234
    Sep 1 '20 at 8:42
