I removed the tile from the hallway a few years ago and installed hardwood flooring. The tile kept breaking into small pieces and scarred up the walls. I had a heck of a time removing all the thinset in order to get the cement subfloor flat / smooth. I am trying to avoid that in the laundry room. I am laying porcelain tile and prefer not to remove old tile. I have tiled over many other ceramic surfaces without a problem, but there are small cracks here and know that membrane works on concrete, so thought, why not over old tile and then install new tile over that?
Can I install an anti-fracture membrane over old tile that is structurally sound and then install new tile over the membrane? I am trying to not remove the old tile even though it has some minor cracks.
    "I am trying to not remove the old tile even though it has some minor cracks." Why? Is there a good reason you do not want to remove the old tile and install new tile the correct way? How will the new floor height affect doors and transitions? – Alaska Man Aug 28 '20 at 16:15
  • What kind of tile? You may not get mortar to bond well with glossy glazed surfaces. – isherwood Aug 28 '20 at 16:18
