My led lights have worked fine for awhile, but today they wouldn't turn on! When I plug them in they flicker once and shut back off. I tried a different outlet and it did the same thing.
1by the way the LED lights are light strips.– myla duncanCommented Aug 28, 2020 at 10:45
Is the driver putting out nominal voltage still?– ThreePhaseEelCommented Aug 28, 2020 at 22:56
Please edit your post to include some more details, like make/model of the light strips, is the breaker tripping when you plug them in, what other loads are currently on this circuit.– FreeManCommented Aug 31, 2020 at 12:16
Add a comment
1 Answer
Sounds like the driver has failed. If a quality product, there might be a warranty. If a cheap junky product, you probably can't even find the company, at least operating under the name you bought them from. That's part of the business plan that makes such things cheap, in every sense of that word.
In either case, you'll need new lights or at least new compatible drivers for the lights if you need working lights.
1Well if it's quality, the proof of the pudding is in the refund/replacement. Commented Aug 29, 2020 at 2:46
