Backstory
There is a gap between the ground and the wall. Inside I can see the insulation that is there.
Problem
Unfortunately the pet made this insulation a temporary toilet so it has been peed upon a couple of times.
Trying to fix
I've removed the visible part of that insulation (by pulling it off as best as I can) and now there is this gap left, where the insulation is underneath.
I've sprayed the area couple of times with enzyme cleaners (including the gap with the insulation), it still smells weird inside. Can't really tell if its pee or insuline smell, if that's something.
Request for proper solution
How can I make sure that the smell is gone?
Should I fill the gap between the wall and the ground with some kind of filler?
Thank you
    It's really difficult to visualize what you're talking about. Please add a photo to your question.
    – jwh20
    Aug 25, 2020 at 11:27
    Yeah, edit in a couple of good, clear, focused pictures of the overall scene (hit the "sun and mountain" button above the text entry box) and a detailed shot or two of the problem area will make it much easier for people to help you. I'm not even sure if this is indoor "ground" or outdoor "ground"...
    Aug 25, 2020 at 13:26
  • If it's from a dog, keep spraying with bleach. If it's from a cat, forget it.
    – JACK
    Aug 25, 2020 at 14:22
You’ll need to expose area, clean with bleach and let air out for a day before installing new insulation then covering area. Kind of hard to visualize w/ out photo.
