I need to replace a dual electrical outlet and fix some melted insulation/exposed wires inside. I found that the two sockets are wired like this:
Coming out of the wall I have dedicated wiring for each socket, but for some reason the sockets are also connected to each other (ground to ground, etc). Why the "extra" wiring? Should I keep it?
Edit: these are Type F outlets in Germany.
