Replacing an old 3 way switch with a new dimmer 3 way switch. The old switch had 2 traveler wires connected to it (black and red), the ground wire, and the 'hot' wire. I also noticed 2 neutral wires (both white) that were bundled together and capped. Now, the new dimmer switch has the green screw (for the ground wire), and then 2 screws on each side. According to the instructions, the top left is 'neutral', the bottom left is for a traveler, the top right is for the hot wire, and the bottom right is for another neutral wire. So I'm a bit confused here - I have 2 traveler wires but only one spot on the new switch for one. There are 2 spots for neutral wires, but they are bundled together in the outlet. Thanks
FYI - this is an Eaton WFD30 smart universal dimmer... Edit: In the pic, the 2 white wires were bundled together and capped (assume they are both neutrals), the black and red are travelers and the other white with the black tape was the 'hot' wire.
Edit 2: Added a pic of the other outlet. Looks to be wired slightly differently than the one I was installing the dimmer on. I can out the dimmer on this one, whatever is easier. This one appears to have 3 white wires bundled together.
