What can I expect to find if I open up the wall above the fireplace (behind the T.V.)? Brick, wood studs, etc..
This is an exterior wall.
Thanksenter image description here
  • How far does the chimney stick out of the outside wall?
    – JACK
    Aug 21 '20 at 22:26
  • 16" from the outside wall.
    – slock
    Aug 21 '20 at 22:33
  • How thick is the chimney above the roofline?
    – Jasen
    Aug 22 '20 at 0:54
You probably have studs and drywall/plaster like the rest of the wall and a cutout where the fireplace is mounted with the chimney going up the outer wall. The brick and mantel probably go back to the unfinished wall.
