The driver circuitry May have been damaged or had cold solder joints that are failing.
The led dimmed or not should be almost immediate.
I have had drivers that had cold solder joints on very high end fixtures that caused the fixture to take longer to light to start with and a while later it would not light at all as these fixtures were almost 500 ea I figured out the problem and it a bad solder joint (I don’t have to mention where the fixtures were made but it was not the US)
If you still have a warranty I would recommend trying that route because if any LED won’t light in under a second something is wrong.
I would also recommend getting DLC approved lamps or fixtures DLC is design Light Consortium and they usually have a 5 year warranty (some 3 year) .
All the ones I have seen also have UL listing (I have to have this for industrial or another nationally recognized 3rd party facility).
Since the lights are taking more than a second there is a problem it could be a loose wire can be a possibility. My experience has been bad drivers on almost 100% of my failures.
