I am relocating a sink from one wall to the perpendicular wall and I want to know if there are any potential issue with this
I am wondering if instead of breaking the floor I could do this:
just run ABS across the walls (1) back to (2) which is the existing plubing for the old sink
It is too tedious to create the traps in the diagrams but assume they are there
this is the new layout (please ignore the green pipe you see at the left of the picture) enter image description here
  • your shower drain appears to have no trap, that's not going to work well.
    – Jasen
    Aug 22, 2020 at 7:00
  • too tedious to create the traps in the diagrams but assume they are there
    – MiniMe
    Aug 22, 2020 at 14:41
Of course you could, but read the applicable code: your run is very likely too long to be unvented. You'll need to vent this - run another dry vent pipe higher up and tie it to your newly proposed "white" vent stack.
  • the only white pipe there is the one connecting the shower, that is a drain not a vent I am not sure where you are suggesting I should add a vent pipe> I can add a AAV under the sink in the new position. Would that work?
    – MiniMe
    Aug 21, 2020 at 18:20
  • Forget about AAVs. They are regrettable abominations. There's a white vent pipe you propose to add in your other posting, on the other side of the drain stack (the gray vent is on the "wrong" side in this case). Anyway, just vent this properly. You have to and you won't regret doing it right. You're opening the walls anyway, so just run the drain and the vent pipes when you're there. Easy. Aug 21, 2020 at 18:29
  • @MiniMe the drain from the sink goes into a sanitary tee at the wall under the sink. The bottom of the tee is the drain and the top of the tee is the vent. Both pipes from the tee can be routed through the wall to tie into existing or new drain and vent pipes.
    – Alaska Man
    Aug 21, 2020 at 23:16
    @MiniMe This article illustrates why there is a length limit on the trap arm, the part of the drain pipe between the fixture trap and its vent. If you exceed that limit, your drain may siphon all the water out of its trap and allow sewer gas to vent into your home. AAVs can be applied to work around this limitation but your building official may not approve it in your proposed installation. jlconline.com/how-to/plumbing/… Sep 22, 2020 at 2:50
  • Thanks @JeffWheeler my design evolved please see my other threads posted here. I added adequate vents to the design and shortened that run
    – MiniMe
    Sep 22, 2020 at 3:14
