So I have these built-in cabinets (particle board) that are probably 15 years old. They looked fine maybe 3 days ago. Yesterday I noticed fractures and cracks forming in the base on one side of a row of cabinets. There's a similar crack developing on another cabinet but it's not as bad. The large crack in the image has doubled in width in just 12 hours. I'm guessing that it's due to water damage from a nearby pet water bowl. Have never seen any thing more than 2 table spoons of water on the floor and that was rare. The bright splotches are because paint was added over the years. It blends to the naked eye.
I have a lot of canned food in this cabinet (not visible in images) but that's been true for years. Looks like weight is causing the fractures but I know the piece of wood on the side (with the huge crack) shouldn't even be load bearing. I had to take it out and put it back 2 years ago and there was no weight on it. There are support feet under the cabinets. The other strange thing is that I have similar cabinets in an uninsulated garage that show zero issues.
Do you think the cabinet is in danger of collapsing or is it just an optical illusion?
What's the best way to fix this? I don't want to do a fix that will quickly fail either.
