I have a White Rogers 1E78-144. My house has heating only and no AC.
The current wiring only enables the fan to run when heat is required, even if I force the fan switch to ‘on’ and set heat to ‘off’. If I set it to cool or off, the fan won’t run no matter what.
In other words, if I want the fan to run, it must come with heat, which won’t happen if it’s warm enough in the house.
Is there a way to bypass the heat and just have the fan on?
