I decided to upholster my wooden dining chairs. These chairs were 100% hardwood and finished in glossy polyurethane (i.e. had no padding)
I just finished working on one chair and realized that I had over-sprayed the glue on chair legs, in areas I didn't plan to cover.
The glue I used is 3M Scotch Super 77 spray can.
Is there a way I could remove the glue from the surface of wood without damaging wood surface or surface finish?
There are some fibers stuck to the glue on wood surface. glue is not visible in picture, but it can be felt when touching wood surface.
@username
to let them know you've answered - that's all it takes. Well done, BTW, including a picture without prompting!
